Just reading as well cut line 58% chance to move to plus 2mostonmike wrote: ↑Fri May 16, 2025 5:13 pmI keep getting problems with the asterisk appearing on the staggered starting players. Another fix implemented.Walla Walla Dawg II wrote: ↑Fri May 16, 2025 2:51 pmOur leaderboard is 3 holes behind... is there another issue?
The cut is about to move to +2 I think. Good job because as it stood moments ago, DTrain would be the only protagonist through to the weekend and will be the default winner.
Edit: it does look like that cut is going to stick at +1.
OT: Inaugural PGA Championship Contest 15-18 May 2025
Re: OT: Inaugural PGA Championship Contest 15-18 May 2025
Lowry got screwed having to hit out of someone else’s divot. Might end up costing me this tournament if he misses the cut by a stroke
- mostonmike
Tense scenes now as we reach the end of Round 2.
-5 Juliooooo - will make it through, as long as Lowry makes the cut. He's currently +2 with 2 holes to play. Just enough
-4 WallaWallaDawg - can't make it to the weekend, despite being second - UNLESS the cut goes to +3, then he qualifies
-3 mostonmike - makes it through as long as Rory doesn't blow it in the last 4 holes, he's currently E
-2 TLO Idaho - another praying for Lowry to get through, and Sepp Straka who needs a par on 18 to stay at +2
-1 baller - pray for Straka on 18, plus hope that Min Woo Lee, currently +3 with 4 to play gets his act together
-1 D-Train - only Tony FInau, who's E after 13 can blow his spot in the weekend.
+3 rockycola - eliminated
+3 Seattle or Bust - eliminated
Edit: Cut projection might be bouncing between +1 and +2, as we now have the exact 70 players at +1. This will be very, very tense
Cut line now projected at +1. Need a few guys to bogey who are at +1 I think.
- mostonmike
That cut moving to +1 looks to have blown it for many on here
TLO Idaho and
baller
All need the cut at +2 or they are done for
TLO Idaho and
baller
- mostonmike
AS IT STANDS
Only my dear self and Darren will be heading into the weekend.
IN THAT SCENARIO
I will run the scoreboard with mostonmike v D-train basically competing for the title.
To create some interest, I will then run a separate comp underneath with the 6 protagonists who have 2 players going through to see what happens. We will need a name for the event, PGA Weekend Championship is the best I can come up with at short-notice. Darren and I will also have an advantage in that, as we will have best 2 players counting out of 3.
What's the analysis on how this occurred?
I wanted to use this format for the Open (British Open) in July. The time difference screws you all over with making changes after round 2, so I was looking for something that means you pick at the start and are stuck throughout the competition.
But we have to improve it if only 2 protagonists qualify.
IN THAT SCENARIO
Unless Min Woo Lee Birdies 18mostonmike wrote: ↑Fri May 16, 2025 10:17 pmThat cut moving to +1 looks to have blown it for many on here
TLO Idaho and
baller
- mostonmike
is it top 65 plus ties? We need 2 more to get to +2?
